I have read somewhere(I forgot where) sometime ago that Briggs uses different governor springs,depending on the engine's intended purpose. This is in reference to the 500cc vertical engines,the 31C707-3026-G5 ,for example. The springs look alike but are color-coded as to the max rpm it will allow. Is there a source to find out any more info on this?
I know there is a wealth of knowledge here,so maybe this is the bast place to ask. TIA
