briggs and startton 6bhp
dcfcmark
I have a briggs and Stratton 6bhp engine inteK pro65 ohv
I have had to rewire the mower as no electrics I need help
the engine turns over does not fire I have a spark at the coil and placing the sparkplug near the plug hole ignites the vapour - PLENTY OF FUEL
All of the cut out switches have been removed the coil connector is earthed and connected to a switch which provides a cut out.
when the spark plug is in the engine it turns over will not ignite and does not even try to start.
I have A wire from the magneto DOES THAT NEED TO BE EARTHED?
The large lever under the magneto connected to the Carburettor is that a engine stop ? Cant see as engine is in place
Help please
motoman
Send some pictures if you can and the make, model number.
