Have an older Craftsman mower with 6.0 Briggs engine. At first I noticed it did not have spark with kill wire attached, so I disconnected and now have spark. Tried to start it with starting fluid but it only "pops" a bit but does not start. Checked the flywheel key and it looked fine but I replaced it anyways as a precaution. Still the same issue. I am starting to think it may be one of two issues--1) Weak spark or 2) Low compression.
Seems okay when I pull the rope but do not have tools to measure compression. Any suggestions to the possible causes? I regularly work on mowers but this one has got me stuck.
Thanks
Thanks
