I have a 550EX on an MTD Yard Machine that is about 5 years old.
The engine will kick over with starter fluid, but will not stay running. Here is what I have done so far:
1. Replaced carb (after cleaning original carb did not help)
2. Drained (gas tank and carb fuel bowl) and replaced fuel with fresh fuel.
3. Replaced spark plug.
4. Verified, and re-verified fuel is reaching the carb (bowl is full).
5. Verified gas cap vent is clear.
As I said, it will start for a second with starter fluid and run normal, but dies almost immediately and will not even sputter after that.
Thanks in advance for any help you can provide.
