bwestbrook
- Jul 23, 2011
- 32
- 189
I have a yard machines push mower with a 5.75 briggs engine that will not start. I have cleaned the carb and put a new kit in. I have repaired tons of these with this same problem. It is usually the main jet. There is plenty of fuel flow to carb and carb bowl is full. Primer bulb works and will push fuel into the carb venturi. But mower will not start. Yes I would say spark. But when you spray carb cleaner into the carb it will fire up and die after it burns that off. Then I thought maybe weak spark.
The two differences I see are with the fuel from the primer bulb isnt going as far into the carb and then the difference of ignition point of gasoline versus carb cleaner. any help would be appreciated. Sorry for rambling.
