Briggs 5.5hp Intek hard start
Riick
I have a older Toro 21" GTS Recycler mower, (built in 2001) with a 5.5 Briggs engine. This engine uses a rubber bulb to prime the engine with gas.
Once mower would start on 1st or 2nd pull, but has been getting progressively harder to start. Cleaned the carb, new gaskets & float needle, no change, still hard to start.
Installed a brand new aftermarket carb, fuel line, fuel filter, cleaned & re-gapped the magneto, still hard to start;
Just like with the old carb, will only start if I spray some carb cleaner near the air filter.
Once it starts, runs fine, no surging, and warm, re-starts on 1st pull.
Anyone with an idea that might improve things?
Scrubcadet10
Moderator
Staff member
Engine model number?
If it's the engine I think it is, the air filter base could be warped or the primer passage clogged.
Aftermarket carb may be the problem or the gasket between the air filter body and carb is leaking due to the plastic warping.
