skippymud
- Nov 21, 2016
- 11
- 44
Hello All
Briggs 4hp horizontal not running just right. 1976 model 100292 on a Troy-Built tiller. VID:
Flywheel key is intact
Good compression
Carb is rebuilt 100%. I actually tried 3 different carbs and got the very same result
Bowl in tank has plenty of fuel
No leaking fuel
Has good spark
As you can see in the YouTube VID, it just spits and sputters. It idles but only for a short time. When I REV the engine, then it sputters
I welcome any suggestions as to the wrong-goings
Good compression
No leaking fuel
Has good spark
