Working on a Dixie Chopper Iron Eagle 2344. Had to replace the governor. It had been setting about a year. Got the governor fixed, went to start it. Would not start sprayed carb cleaner in it and got it started but was only running on no. 1 cylinder. Found it was only running on the half the carb. feeding the no. one cylinder. So I think boy I hate to pull the carb. on this thing. Got to thinking it is Nikki two-barrel carb. what if I pull the top plate off it and clean the ports for there. So that is what I did. Took a really small drill bit that would go through the office in the main jets and another smaller one that would go through the idle orifices. Put it back together. Started it up and it ran like it should. Who would have thunked it. Just hope it keeps running like it should.
