Here's one for the books.
Customer changes his deck belt due to failure. Engine was running fine before the belt change. After changing the belt the engine develops a surging issue. Just a just happen to happen after the belt change.
Several problems found.
1. Breather hose leaking. Replaced.
2. Fuel impulse hose getting ready to fail. Replaced.
3. Carburetor jets were loose so the carburetor got a complete cleaning and a kit installed.
4. Intake manifold o-rings harden. Replaced.
But none this was the root cause. So what was the root cause? Not ignition, timing, or valve issue. The problem is/was with carburetor. I can kick myself for not catching it during the carburetor rebuild.
