neighborbill
- Jun 17, 2012
- 11
- 87
I have a Troy sickle mower with a briggs 4hp engine. I am having trouble keeping the engine running. I can spray starter fluid in the carb and it runs a bit then stops. I can spray again and it starts. When it wants to die I spray the starter fluid again and it keeps running. Once I stop the spraying it quits running. I"ve also left it sit for a day or two pulled the starter and it ran perfect, but only for a short while before stopping again. The spark plug is pretty black . Not wet, but carboned up.
I've never seen the carb attached to the tank before. Seems like a weird set up. I was looking for a fuel pump of some sort and thought this might be the problem. I don't see any fuel pump.
Any advise?
Bill
Any advise?
Bill
