- Feb 19, 2020
- 86
- 11,048
Okay guys here is one for you to diagnosis.
Briggs 33R877-0034-G1
Originally shattering starter gears. Other techs including JD replaced the starter and the gear a least several times. Never found that the camshaft ACR was broken.
Replaced starter Bendix assy and camshaft. Mower was return with it running fine. Before the customer could even unload it, it surging heavily. I found the stator destroyed because they didn't keep track of the wire clip. Replaced regulator due the shorted stator.
Engine continued to surge so I went back in to check the governor which was like new.
Now here what else would surging and it is not the static governor adjustment. Note: a new carb and ignition coil was also tried.
Just to note I do have a final solution to this just seeing if anyone can figure it out.
