tgzzzz
- Aug 11, 2012
- 9
- 82
Mine's still running fine at 170hrs but my question is: Is there anything I can to to pre-empt failure? I've read of a work around with the starter so you can keep using the engine IF the parts fall harmlessly in to the sump. But engine becomes junk if the parts hit other parts. I haven't seen anything along the lines of a kit with better parts, and apparently the decomp lever is pot metal, hence the breakage. Wondering if a machined steel lever might be a good idea ahead of failure. Thoughts?
