pinevilleoxbow
guys
looking for thoughts on my situation.
briggs 24hp platinum on a craftsman zero turn
randomly mower quits while cutting. 200hours on it.
i pull it back to the shop and do some quick checks.
determined that if i pull the right plug completely the motor will fire and run on the left cycylinder.
will not runn if the left plug is pulled and right plug is in
done a compression check and have both 150psi
swapped coils for the hell of it.
checked for spark and have spark on both sides.
have changed plugs
right side seems dry.
sprayed some started fluid in it just to try. no difference.
have changed plugs
