Briggs 2 hp 60102 or 3 hp 80202 coil replacement.
silver1
Can I substitute coil 398593 or 496914 for old coil 298502 or do I need 591420 replacement kit?
What about the kill switch wire to carb.. Time to update from points.
Both of your engine will use a 591420, other numbers you posted will supersede to this.
silver1
Thank you for the reply. I will check out the difference other than price.
Silver1
silver1
Silver1
The replacement is twice as much and you only get the kill wire(s), & plug.
Thanks.
