Export thread
Briggs 191707-5661-01 Carb Won't Adjust
#1
S
SHOOTERTPP
Hey folks.
I'm working on an 81 or 82 model, John Deere 108 Lawn Tractor for a rancher friend of mine out in west Texas.
It has an 8hp Briggs 191707-5661-01 engine. It has the 1 piece FLOJET carburetor on it.
Originally all I was going to do was replace the starter. Someone had put an iron pinion gear of the aluminum ring gear so I ended up replacing the ring gear as well. While I was in there I decided to check the gap on the points and when I took the cover off, I found it was full of oil so it replaced the point system with the new magnetron coil eliminating the points and condenser.
Before I started this the engine would ilde, but when given fuel it would run rich and put out some black smoke.
After replace all the other parts and starting it. The same thing happened. I purchased a rebuild kit for the carb, clean it and replaced all the parts.
It still won't adjust. I started as per the instructions 1 1/2 turns on both the main and idle screws.
No matter how I try to adjust it, it won't work right. If I screw the main jet in, the idle comes up and it quits putting to back smoke, but it runs at what seems like full throttle.
Any ideas on what I could be doing wrong?
#2
M
Mikel1
Sounds like there's still a blockage in the carb if it's still running at full throttle with main all the way in. I'm guessing air filter is clean?
Here's a link for you- http://outdoorpowerinfo.com/repairs/briggs_large_one-piece_flo-jet_carb.asp
#3
S
SHOOTERTPP
Air cleaner is not on due to the idle air adjustment screw being under the air cleaner. It will run just about the same way with both adjustments all the way in as it does when they are at the starting point of 1 1/2 turns. As I screw the main needle in, the engine picks up speed to the point where I think is running close to max rpm.
I used two can of cleaner to clean every passage in the card that I could find/see. It's easy or remove and I can clean it again after I remove the new jets.
#4
S
SHOOTERTPP
Mike, I appreciate the link to the procedures. I'll remove the carb again tomorrow, get some more cleaner and give it another try using the pictures in the link.
Thank you!
According to the rancher the mower hasn't been used all that much. Most of its life it has been sitting under a covered carport.
For all I know a mouse has died in the body of the carb and is restricting air flow. I did not remove the welch plug but will tomorrow.
#5
M
Mikel1
Your welcome, I hope that helps you out. I'd hope you would've noticed a mouse in there:laughing:.
I did have to clean an atv carb 5 times before it ran right. The person I bought it from had changed out a rusting tank to a plastic tank but didn't change out the fuel shutoff(petcock). So the rust was in there clogging back up the carb.
#6
S
SHOOTERTPP
I just finished an ATV carb on a 1988 Honda 300 TRX for my brother. It had set for a bout 5 years after he had the engine rebuilt. It was a breeze compared to this one.
The one thing I'm not sure of is if anyone has been into the carburetor before. I am thinking some one has.
One of the ears that holds the float in place is broken and I didn't find the missing piece in the fuel bowl when I disassembled it. The other ear is holding the pin in place.
One thing I may have missed, is there supposed to be a retainer to hold the needle valve to the float? When I disassembled it, there wasn't one on there, but the link shows one in picture 12. The instructions also mention the need for one if there was one there when it was disassemble, but say to leave it out if there wasn't so I didn't put it in.
I was thinking it was odd it didn't call for one but thought it may just fall down by gravity, but am now thinking I was wrong. I'm not saying that's what could be causing the idle problem, but not being a carb guy, I don't know.
#7
S
SHOOTERTPP
I must have the small body as my carb, while very similar, is a bit different than the one in the link.
I have taken some pictures and will post later.
#8
M
Mikel1
That atv carb was on an 87 Honda Fourtrax 250.
With the float ear broke, is the float operating normal?
Here is a link for 191707-5661-99 carb diagram, you may be able to google to find the 01.
Diagrams
#9
S
SHOOTERTPP
The ear is broken on the Briggs. Yes the float works even with it being broken. The pin is tight enough on the other side the pin only drops about 1/32 to 1/64 on an inch on the broken side.
I'm leaning now, it being not the carburetor that's causing the problem.
I took the carb off and then put it back on with the choke wire attached but with the throttle linkage removed.
I closed the throttle by using the ear on the back side of the carb. It didn't start. Next I cracked the throttle open about where in normally starts at. It started right away, but at a higher than normal idle.
I then very slowly moved the throttle in the direction it should go to idle down and the idle slowed to what I consider a normal idle speed. I then adjusted the low side to where it ran very smoothly.
I then revved it up to what I think is max rpm and adjusted the high side to where it sounded good and wasn't puttin out any black smoke. I then returned the lever back to idle and it slowed right down to a nice idle. I them snapped the throttle open and it accelerated right away without any hesitation or smoking. Just like it should.
Return it to idle and moved it to high several times and it was perfect.
Took the carb off and replaced the linkage for the throttle and the problems returned. Go figure.....
Possible governor problem?
#10
M
Mikel1
Oh I see so it's not the actual float. Have you tried moving the governor spring, usually a few holes to try. Another link for you- Adjusting the Governor | Mower Maintenance | Briggs & Stratton FAQ
#11
S
SHOOTERTPP
Here is my deduction:
The throttle is not fully being closed by the linkage. I assumed that the linkage is supposed to be that way, but after some consideration, I'm not so sure.
It appears the linkage that is on there is holding the throttle plate open anywhere from 1/4 to 1/3 of the way open. Me assuming it was correct, I was trying to adjust the idle air when the butterfly was calling for more fuel. Ain't never gonna adjust properly.
The arm on the throttle mechanism cannot travel any further forward to close the butterfly more.
Since I am not the owner, I have no idea what someone else may or may not have done. Looking at the end of the wire that connects the rod to the arm on the throttle shaft,
it appears to me to have been cut with a pair of pliers or dikes, as it is a bit pointed. I would assume the factory ground the ends flat before bending the wire.
On a whim, I removed the carb and removed the throttle linkage, but left the choke linkage in place. I manually closed the butterfly/shaft until it stopped completely and tried to start it. It would not start.
I then held the butterfly open just a very little bit and it started right away and idled nicely at about the right speed. I adjusted the idle air until I found the "sweet spot". I then open the butter fly wide open and adjusted the high air until it quit putting out any black smoke.
I then returned it to idle and back to wide open slowly a couple of times and it accelerated nicely. I then snapped it wide open from an idle and to my amazement, it jump right up to full speed without any hesitation or stumble.
I then removed the carb and hooked up the throttle linkage and reinstalled. Back came the problems of it not wanting to idle or accelerate and putting out black smoke when given any throttle.
Any suggestions???? Could it be a governor issue?
#12
M
Mikel1
What are your settings on the main & idle from bottomed out position now? I don't see anything out of the norm with your pics. I have 2 flatheads with the same setup that are out 1/4 on throttle plate, both run great.
#13
G
Gearhead0101
I've never heard of one that didnt, but on some of them there's just a notch in the float that holds the needle instead of a separate retainer. It might not be (and probably isnt, it barely makes sense as I'm typing it) but if you had a serious enough vacuum leak, it could theoretically interfere with carb adjustment, but a leak that severe would give more symptoms than just that.
#14
S
SHOOTERTPP
Started out at 1 1/2 on each one. I can get it to idle good but the RPM's are high. If I run the throttle to high and try and adjust the high side it races out of control. And when you move the lever back to idle, the RPM's don't drop.
Without the throttle rod in place, I can adjust each one and it runs and and adjust just fine.
I'm doing a barbecue cook off right now, but will try and get a video of it on Sunday.
#15
M
Mikel1
So with all linkages hooked back up, you can't go from full throttle back to idle. Is the throttle plate staying open when this happens and not closing? If that's the case then you have a governor issue. You can take off governor spring and manually open/close throttle to confirm.
#16
S
SHOOTERTPP
Mike, I don't know. I hadn't noticed. What is puzzling me, is why with the linkage removed, it will perform like it should idles corrctly and will rev up and come back to an idle with no problem, but as soon as you hook the linkage back up, it runs rough at idle and wont rev up very quickly and when it does, it runs way to rich, all without any adjustments to the carb.
What you saying makes sense, the governor is what to do one thing while the carb wants to do something else.
I'll have to read up on the operation on the govenor on this thing.
I'll try that in a few minutes. I good some much need sleep after the BBQ marathon Friday night and Saturday and now have a much clearer.
#17
S
SHOOTERTPP
I tried again today with all the info but to no avail. I finally built a longer linkage to allow the throttle butterfly to close more and all is well. I can now use the idle adjustment screw ( not the idle air adjustment) to raise or lower the idle. It now idles and revs up and returns to idle on command.
Now for the next problem, non engine related. When I engage the pto switch the engine dies. I tried finding the wiring schematic but no luck so far.
I did disconnect the pto clutch at the connector down by the deck and the engine still dies when the PTO switch is engaged.
Anyone have a clue?
#18
M
Mikel1
Incorrect linkage or tampered with?
#19
S
SHOOTERTPP
It looked factory, but the again it didn't.
Like it shows in the picture the butterfly would not close very much. I think someone may have cut and rebent the factory linkage to give it more fuel to keep it running when the carb became dirty.
I figured out the problem I asked about in my last post. Some one had disconnected the seat safety switch and had grounded the white wire that comes out of the wire loom that goes to the safety switch to the frame.
Removed the wire from the frame and it will now run, engage the PTO and the blades turn. All is well.
The bad thing is John Deere no longer sells the seat safety switch for that model. I have the guys at the deere dealership trying to find a replacement.
#20
M
Mikel1
People do some odd stuff sometimes. Well then it sounds like your almost done. Your rancher friend should be pleased with your efforts.:thumbsup:
#21
S
SHOOTERTPP
It's the least I can do for him. He gives me unrestricted access to his ranch (27,000 acres) for predator hunting and let's me deer hunt for free and let's me stay in his lodge.
I'll be headed out there this weekend and I'll check on one of his water wells. The cows ate the electric line and the water well people are telling him it ruined the pump. I just have a hard time believing it.
The controllers have a reset on them in case one leg of the 220 goes down. And I do know how to check the pump without pulling it and the controller as well. We shall see.
Next up will be a Sears Craftman mower that a friend of my wife has. It needs a lot of attention as well.
I appreciate your help.
#22
M
Mikel1
Wow, sounds like a great arrangement for both of you. I also deer hunt but no where near the land you have access to and I share it with five other members.
Those cows need to find something else to eat. I know very little about wells even though I have one. Years ago I did have it pulled three times, the first time(original problem) motor was bad also had new piping installed, second time pump wouldn't work, third time motor wouldn't work. Is the controller that metal box(220V lines going in and back out) or am I way off base?
