Mattmotors
- Oct 10, 2011
- 84
Briggs and Stratton 121S07-0167-F1 190cc.
Ok, I know it is freezing here , Upstate New York. I have the Briggs on a DR Power Wagon. It seems as the if the auto choke and throttle are frozen. It starts and runs and I know the choke is stuck on by the way it runs and smells. I run it for a few minutes then shut it down, The heat from the engine usually frees things up. The choke seems to release first . The choke will release and the engine will shoot off like a rocket, Wide open. no control on the throttle lever. I shut it down for a couple more minutes, then the throttle will release. After that , It runs like nothing happened.
Anyone else experience this? I think I probably have to WD40 the choke and throttle shafts on the carb. The problem (for me) is that the engine Is so low to the ground that I'll have to lay down to get to it. I'll make sure I wear my Medic Alert button. Please share your thoughts. Thanks, Matt.
