Hey Guys
I picked up a Troy Built Lawn Tractor with a B&S 18.5 HP engine.
Model Type Code
31P777 293-E1 04 702ZA
The mower has not been taken care of very well. The guy I got it from stated that he had gotten the mower back from the repair shop at the beginning of spring and they had replaced the Solenoid and put a new battery in the tractor. He told me that he started the mower up the other day and it "almost immediately" ran out of gas. He stated that he filled it up with gas and then tried to turn the key and the tractor would not do anything. In his disgust, he sold me the mower. Im thinking that some type of failure happened and the mower "just happened" to be low on fuel.
I got the mower home and checked the battery with my multi meter, It read 12.63 volts. I turned the key and I could hear the solenoid on the float bowl click, but the Ignition solenoid wont click. I then jumped the solenoid and the starter engaged but would not turn the engine over. So I think "starter, Valves to tight, Engine Hydro Locked etc. So I went to take the spark plug out of the mower and the dang plug was barely in the spark plug hole about 8 turns in. Took the plug out, jumped the solenoid and the engine turns over fine. Take my finger and place it in the spark plug hole to get a "red neck" compression reading and the engine stops turning and the starter starts whining when I put my finger over the hole and let it build compression. Just me covering the spark plug hole with my finger and spinning it over is enough to stall it out.
I decided to check the valve adjustment and with all B&S OHV they were a little out of adjustment so I adjusted the valves to INTAKE .007 and EXHAUST .005. Tried spinning it again and no change. Oh, by the way, the engine was not hydro locked either. So I changed the starter. No Better.
Im at a loss guys!! Has anyone ran into something like this before? I don't know where to go from here.
Thanks in advance
Model Type Code
Thanks in advance
