My neighbrhood had a quick flash flood yesterday. My yard had 3 feet of waer in it in spots. Of course, my Craftsman Lt1000 mower was in the yard and was nearly completely submerged for 15 to 30 minutes.
I have changed the oil, oil filter, fuel, fuel filter, and air filter. I have used some small engine "tune-up" spray (that is sparyed into the spark plug opening to remove mositure and buildups) . I cleaned the plug, but did not replace it.
The mower will turn over quickly. I have checked for spark using a spark tester, and do ha:thumbdown:ve spark. It will not fire off and run. I have tried using quick starting fluid, but it still will not fire off---just spins and spins.
What else should I do to get this engne running? I cannot afford to send it to the shop for "pro" repair.
