briggs 12.5 starter wont engage the fly weel
NTX8232
the fly wheel
SeniorCitizen
the fly wheel
To determine if the starter pinion gear will travel up its shaft as designed to engage the ring gear, remove the starter and using jumper cables momentarily touch the + to the starter terminal and the - to the starter case.
EDIT: You can probably test using jumper cables from the battery with the starter still mounted. The last one I did the pinion gear was stuck and new parts in that area were required.
