Brand new Airens Rider, Bad Luck, Need HELP!!
berggy86
New Ariens Rider Model 936083 42". Couple weeks ago i ran over a small stump, Blade was bent, fixed it.
Now when i push the gas pedal down it doesn't have the same power, almost sounds like something is rubbing. I bought new blades and had the mower deck off and drove it, if i push the pedal down a little it sounds good, its when i push the pedal all the way done i hear the noise and it seems to slow the mower down
mechanic mark
Take it back where you purchased tractor & tell them what happened and be totally honest, repair should be warranty item and try to avoid stumps.
