Toro Timecutter brake not disengaging
:confused2:
After starting the TORO Timecutter, the automatic brake does not disengage when the motion control levers are moved in. However, when I carry out the steps for manually pushing the mower, I can hear the automatic brake disengage, and it does actually disengage, and I can push the mower, and after undoing these steps, the brake again automatically becomes engaged, as I presume it should. Thanks for any help!
:confused2:
