Repairs Brake lever moving
Knots
This concerns a 2014 Turf Tiger with watercooled Kawasaki DFI engine.
If I am mowing right to left across the face of a moderate slope and turn up hill for a few feet and the back up to resume my original direction of travel the brake lever jumps up and hits me under my left leg. As soon as I resume going forward across the slope the lever returns to the normal down position.
Took it to the Scag dealer and he did not find anything wrong. I have a friend that has an older air cooled TT that occasionally does the same thing.
I have had three of these same machines and this one is the only one that does it.
Any help would be appreciated.
Thanks,
Knots
Knots
Mark,
Are the instructions you mentioned from a Turf Tiger operators manual or some type of service manual?
Thank you,
Knots
BlazNT
He sent you a link to the owner's manual.
Knots
I understand that the problem could be an adjustment issue but I don't understand why it only happens in situations like I described in my original post. Going the other way or turning the other way does not make the e-brake lever jump up and hit your leg. If you are day dreaming, it is easy to imagine for an instant that a snake has hit you. That's what it feels like.
Thanks guys,
Knots
Mad Mackie
I would jack up the machine, set the rear on blocks, remove the rear wheels, inspect the wheel motor mounting bolts and the brake system. While there I would readjust the brakes per the manual, reinstall the rear wheels and torque the nuts to specs.
BlazNT
If you could have someone video it and up load it to youtube. We would need to see it from the side of the break lever.
