B737capt
- Jun 21, 2012
- 3
- 13
I have a fairly new BR800 and this is my 3rd one. What I'm having a problem with is when I use the throttle setting lever as they call it in the owners manual, to wide open, moving the tube left and right blowing leaves pulls on the cable and pulls the motor rpm down. There isn't enough friction to hold the throttle wide open. I took the handle a part but didn't see anything to increase the friction. I haven't had this before on previous units. Anyone else have this issue and found a fix?
