LawnWizard
- Nov 17, 2021
- 12
- 81
BR800 blower, runs perfectly but can not shut off with kill switch. I used ohm meter to verify both the yellow and black wires in the handle have continuity. I also cleaned the contact point on the kill wire inside the handle. I suspected bad ground b/c before cleaning the contact point there was no response from the kill switch. After cleaning, it will cause the engine to sputter just a bit but not die. But by using the choke and kill switch it will die. Before, I would have to full choke and rev the throttle to kill it. Kill switch had ZERO effect on it. Is there such a thing as a coil that will not ground? Or is there something else I'm overlooking?
All suggestions are greatly appreciated.
Thanks!
Thanks!
