BOP Quickie 32 'Step Saver'
lorenjlobbie
Hi all. 2010 Better Outdoor Products walk behind- looking for the trailer-like stand-on attachment called the 'step saver'. Any clues?
Sounds like you are looking for a Sulky be it one wheel or two wheel version.
Here is an example of a one wheel type.
An example of a two wheel version.
Now of you need one that will attach easily and the one for this mower is mounted differently. But should easy to modify an existing Sulky type unit.
