sgkent
- Sep 27, 2017
- 31
- 1,681
Hi - I have a Bluebird dethatcher that is about 20 - 25 years old, that I bought used. The fuel pump and subsequently, tank were bad, but after repair, it runs steady now with new parts. I plan to restore it to an even better condition in the next couple months, and one thing I have not sorted out is adjusting the governor. I think the best solution is to buy a book or find good articles on this engine to be sure all the bases are covered in properly adjusting things on it - governor, speed, valves, etc.. I may even replace the rings because it burns a little oil, although I have read some of the 8hp models have valve seals that wear out. Otherwise I have to search the Internet item by item, to be sure I have the correct procedures. The engine is a white Briggs and Stratton, pull start, with numbers 8HP, 192402 0645 A1 9609 1 91 A . The Bluebird is a model 820, and that company did provide the best pictorial of which dethatcher model they think it is, a C18 but there is nothing on the engine. Any suggestions on an available Briggs book that would cover this model engine?
