bolt broke off
upupandaway
I have a quantum mower motor where 2 bolts that held it to the mower deck broke off in the engine sump.
I never had to extract this so for anyone who did - is it a pain to remove(I assume heat it up wiht a torch and whack the bolt) so is it worth the trouble??
TIA.
Scrubcadet10
Moderator
Staff member
How did they break off, Flush with sump? a little sticking out? or recessed?
I have good luck with left hand drill bits or EZ outs.
upupandaway
Yes, flush with sump. :-(
I'm thinking if it is strong enough to break the bolt, it may not be worth the trouble to try to remove it...
Scrubcadet10
Moderator
Staff member
soak it in Kroil or Liquid wrench for a day or so.
or depending on where it's broke out, you might can drill it out (exact size bit) and use a nut and bolt. that's how i affix most quantums to frames.
hlw49
Why did they break does it have a bent crank shaft.
