Bobcat 52" Z-mower, mower deck question...
CFDBattChief
On my mower deck, there is a bracket with 2 tensioner pulleys attached. The bracket has a lot of play in it, it wobbles pretty bad. There is some sort of a cap with a rubber seal on top of the shaft that I think somehow has to be removed in order to get to the bolt/nut holding the bracket to the post. I have never seen one of these kinds of caps before, and before I destroy it trying to get it off, I was wondering if anyone had seen or used one of these before.
Here is a link to the schematic:
http://cgcequip.arinet.com/scripts/EmpartISAPI.dll?MF&app=CGC54&session=ff80f3a1-5334-44ca-9a7e-13fec842d75f&cat=4&TF=epcFrame&assem=6296&highlightNode=No&selAssem=3524&mdDescrip=942222A%20-%20ZT%20223%2023HP%20KAW%20W/52%20Side%20Discharge
I would like to inspect the shaft to see if there is wear on it and replace it, or merely tighten the nut/bolt to take the wobbling out.
Thanks for any assistance.
CFDBattChief
