Blown Fuses
WP Riebe
Electrical problems . Fuse blows on 61" Bobcat ZT . Then motor runs very poorly , runs fine when I called dealer they said to replace coils , I did . and have same problem . Anyone have any repair Ideas . or the same problem . WP Riebe
Hands on, you have a hot wire touching ground somewhere. Check all connections by unplugging, visually inspecting and plug back in if they appear to be ok. Check wire harness for bare spots, chafing, hanging loose. Inspect all switches, relays, and fuse blocks in same manner, look for melted plastic & if you find it you have a problem there. Lastly, check all ground straps and cables for being tight and secure.
Schiller Grounds Care Literature Portal Enter your model & serial numbers and see if there is a wiring diagram in your manual.
Hands on, inspect everything electrical looking for bare wires, loose connections, burn marks, corrosion, rust, including all switches, relays, fuse blocks etc. Let us know what you find, thanks.
