Blown 30amp fuze
Ok lets get to the skinny - I SCREWED UP - Was in a hurry when I installed a new battery, Not paying attention and talking to my son - HOOKED THE DANG THING UP BACKWARDS - NOW, The 30 amp fuze keeps blowing as soon as I turn the key, Before it even gets to start position - What the HE@# did I tear up THIS TIME!!!! It's a Craftsman DYT4000 - Model 917.2736403 - I really need to get it fixed quick, I use it to mow close to 3 acres of 30 degree banking, that My John Deere LA130 isnt capable of climbing, due to NOT ENOUGH POWER..... But thats another problem, for another day - I CAN HEAR THE GRASS GROWING ON THE HILLSIDE OUTSIDE - HELP!!!!!!!!!!
additional info - The Wiring harness's all look brand new (118hr's on tractor - pressure washed after each use, Garage kept) NO MELTED, OR FRAYED WIRES, Not grounding out ANYWHERE - I FRIED SOMETHING, when hooked battery up bass-ackwards - Starter turns freely, bendix moves, {While using 2 jumper wire's, instead of fuze} with key in ON position, touching wire's together cause arc.... Have also tried disconnecting regulator, mounted on block beside starter, With same result - Blown 20/30amp fuzes.... It eats em, as fast as I can replace em - replace fuze, turn key on, POP goes the fuze....Switch checks good :( I wish it were that simple - Ive fried something, when I hooked 360 amp battery up bass-ackwards - It made a little (almost grinding) sound, as soon as I turned the key on, after replacing battery, and instantly dawned on me what I had done - - - - Oooops toooo late - - - sound lasted about 1.5 seconds and then the first fuze blew...... 7 more since lol - - - Oh and 1 more tid bit of info - that sound I spoke of, was coming from side of engine (around starter) thats why I disconnected the reg, to see if thats what I fried - No such luck :(
