Blowing Fuses
FloydM
I have a 2007 Cub Cadet GT1554. When I turn the key to on it blows the 30 amp fuse. Can someone help me with this?
First according to wiring schematic you should only a 20A fuse. Here is wiring schematic for you trace down the problem.
If that don't work trying unplugging the fuel solenoid on the carburetor and see if that stops the instant blowing of the fuse.
FloydM
Thanks for the help, I will try the things that you mentioned. Where is the regulator?
hlw49
Rectangular box opposite the dipstick side. 2 white wires on the outside ends and purple wire in the center. Just unplug the whole thing.
