Hello Forum, My name is Sam and looking forward being a part of this forum. My lawnmower is cub-cadet comerical 60" tank, mfd date Dec 2001
My problem is blades not turning at times, maybe more likely when hot.
things i have done
Clean battery post and it tested good.Charging good.next ohm check the cirects to PTO. Clean connections, test pto switch. there was some resistance I don't think it was enough to
cause pto to drop out.
I bypassed the seat switch did not help.
I would like to adjust the pto air gap if possable,If anyone could help I would greatly appreciate it.
Regards
things i have done
Regards
