I have an '02 Lazer Z HP. I believe it has the trivantage deck. I'm wanting to throw on a new set of blades, and was looking around at options. I read good things about the gator blades, however, I don't find a direct replacement for the exmark part 1-633482 blades. Can I use any 18" blade with 5/8 center hole? Is it best to just stick with the factory exmark blades? Using side discharge, and the grass I cut is very thick, terrain is hilly, and it's usually quite tall as I only get up to the farm to mow every other week at best. Any advice is appreciated!
