Hello, I have a Cub Cadet ZT1 54 and just recently started having an issue with the blades continuing to spin after the PTO button is pressed. At first it seemed that you could hear the blades slowly winding down, especially if there was resistance against the blades, like grass...but now the blades are continuing to spin indefinitely after the PTO button is pressed.
The mower is still able to start, and the blades do no spin upon starting up, but will immediately start spinning as soon as the PTO button is pulled, but the only way to stop the blades now is to shut off the mower.
I back-probed the wires on the PTO clutch and applied direct battery voltage and did hear the clutch engaging, but it was not as loud as I thought it would be, so I am not sure if it could be just partially seized or not...but it definitely did respond when applying 12 volts directly to it.
I would have thought the clutch was seized, but then the blades would engage immediately at start-up, which they do not.
I was going to go ahead and order a new PTO switch, but I wanted check here first since I have a feeling the switch may not be the issue.
Thanks for your input!
