Hi everyone,
I figured I would post this question here in hopes that someone could help me out. I couldn't find any previous threads on this specific question so here it goes.
I recently bought a bagger for my 42" cut Fastrak (see attached image) for $75.00. It's all steel and heavy as hell. It's not made for the Fastrak and will need a little fab work to get the mounting to work on the Fastrak but I couldn't pass it up for the price and build quality. The guy I bought it from said it was a brand new take off. It is not a belt driven bagger/catcher and therefore will be completely reliant on the lift generated by the blade(s) to push the clippings up the chute.
I plan to use this primarily for leaf clean ups in the fall here in Connecticut. Right now I am running the mower with a set of Gator blades but I know I will have to probably get high lift blades so my questions are as follows:
1) Do I need just one high lift blade on the chute side or do in need two?
2) Does anyone have a bagger unit or can anyone recommend a high lift blade for the Hustler 927368 that generates sufficient lift for non belt driven baggers?
Thank in advance for your help!
Manny
Manny
