After removing the blade, hit the edge of the plate with a hammer to spin the plate on the crank to break it loose. If it is really stuck , heat up the collar on the plate and hit one of the plate edges. It should break free then. When reinstalling the blade, torque mounting nut to 45 lb ft.
