Blade Choice(s).
DJH
I'm new to the Hustler forum and have a question on blade choices. I live in the Pacific Northwest where the grass is often damp or wet and mow about 2 acres of hilly lawn with a Hustler 20/52 Fastrak model 925401. This mower originally came with medium lift 783753 blades which I soon changed to high lift 787721 blades which work better for me. I capture clippings into a cyclone side discharge basket (I don't mulch) and for fall leaves (or if I've let the grass get too long) I pull a large yard vac. I've read that the Fusion blade 795526 is also a high lift blade and one web site indicates it is cross compatible to my mower. Are there better choices than the 787721 I'm currently using and is one of those choices the 795526 or what do you suggest? Cheers.
