Hello All,
I have a new-to-me Honda HRB216HXA Serial: MAAA-1019089
I mowed with it twice before this happened:
After starting the mower to mow with this mower for the third time after owning it, i pulled it start perfectly fine, about 30 seconds into the mower warming up (i was not touching the mower at all) the blade engaged all by it self... I stopped the mower, and started my troubleshooting. i disassembled the blade brake and compared it to a schematic i found online, and everything seems to be in order, the wear parts are not overworn. But when i reassemble, it doesnt seem like the clutch material touches the spring loaded blade brake part that is attached to the cable that goes to the engage lever. now, whenever i try to pull the motor over, i can hear/feel the blade spinning with the motor. i have gone as far as to disconnect the cable from the brake side of the mower to rule out an over-adjusted cable but no avail.
