oldntired55
- Jun 17, 2023
- 15
- 95
I have an older Broadmoor...#1693840 with CV46016 hp Kohler . with a chi8nese replacement carb , the carb started flooding and belching black smoke when i was mowing the other day, finally quit 20 feet short of my garage. ordered a replacement chinese carb from Amazon... just installed it, will hardly run...again, with the black smoke and rough running. i find it hard to believe 2 carbs could have same problem. if it were an older Briggs carb with an adjustable float, i would suspect float was out of its range and letting raw fuel pour thru vent.my question is, anyone have a fuel pressure spec on this mechanical pump? maybe its forcing fuel past the needle? also. i do not have the 'original' carb... so im running blind here...
