LoseStumpy
- Apr 24, 2012
- 1
- 3
I pulled out my CMM1000 Type 4 for the first mow of the year. After a quick test turn on I went to the edge of the lawn, it failed to start, and then smoke started pouring out
. Once it cleared and I no longer thought it was going to self-ignite I opened the top and found a coil of black wire nearly melted. From some diagrams this appears to be some sort of brake wire.
B&D does not appear to have a replacement for this part (is it just a wire?). If this fails, is the wire the actual cause of the failure, or is it something else? While looking for a replacement part I found there's an electrical-fire-related recall on this mower...is this the sort of thing that B&D will fix under that recall?
