Big dog alpha. What size belt does it use?
BBill
BBill, get your act together. There are two different numbers because you said you need both belts so MParr gave you numbers for each belt. My suggestion is if you don’t understand this, don’t try to change either belt. Might be in over your head.
I didn't know what rotary is! I know there are two different numbers! The rotary numbers made 4!!
BBill
I know how to change belts!!!
MParr
Do you have a Hustler dealer near you?
If so, call them.
