B Bmwz3coupe Member Joined May 28, 2022 Messages 40 Aug 14, 2026 #1 Can the aluminum column shaft be straighten if it gets a mild bend from being stepped on ? ECHO 225 weedeater.
Tiger Small Engine Lawn Addict Community Leader Joined Dec 7, 2022 Messages 2,266 Aug 15, 2026 #2 Bmwz3coupe said: Can the aluminum column shaft be straighten if it gets a mild bend from being stepped on ? ECHO 225 weedeater. Click to expand... Very carefully and gradually it can be straightened, depending upon how bent it is.
