My belt is not broken yet but has two chunks about 2 inches missing. I have been spraying belt conditioner on it. I use a can a year on the belt. anything better to use? Belts are expensive. Mower has original belt on it. Its 3 yrs old. Thanks
Are we talking about the deck belt?
How many hours per year are you running?
I'd get a new belt just in case.
Als,o make sure all pullys are tight & when engaging & dis-engaging blades, do so at the lowest RPM you can. This will also prolong the life of your expensive clutch.
Think about your clutch this way; If it was a car, would you rev it up to max & shift gears? If you do you'll wear your clutch out real quick. My first Grasshopper I wore the clutch out in 200 hours because no one told me to engage & dis-engage at low rpms. My 2010 Grasshopper has 1400 hours & I'm still on the original clutch.
