Belt fix Bronco 42"
jeepmann1
My wife's Bronco (mother's day present) kept throwing belts. I got tired of replacing the A section belts so I found a B94 would work just fine with a little adjustment on the belt keepers attached to the flat idler pulleys. She mowed the yard yesterday which had grown up taller than usual with no belt problems :)
The adjustment to the belt keepers/guides was easy I just beat them back with a hammer till the cleared the thicker belt.
Now all that is left is to make it mow in reverse.
George
Derek101
Look underneath on left hand side there is a wire down to a contact this can be unplugged if an adult is using the machine. Watch that the b-section belt doesn't spread the pulleys on the deck and motor they will separate over time as they are thin
