Belt comes off on deck when blades are disengaged on troybilt bronco.
nowlinrl
  • / Belt comes off on deck when blades are disengaged on troybilt bronco.
Had a small limb caught under mower and bent idler pulley and cut belt on deck. Replaced pulley and belt and now when blades are disengaged the belt comes off on deck.
justin112312
The majority of my shop work was those troy built broncos
Benny R.
Check to be sure the belt is the correct length and check the belt guides to be sure they are close to the pulleys.
ddbtdd
Anytime I ever had this issue if I tightened the nuts on the tension spring to the brake/clutch the problem would go away.
I also noticed at times when I would push the clutch/brake peddle down hard and fast it would cause the belt to pop off especially after the tractor warmed up.
Briana
Welcome to LawnWorld!
We moved your thread to the Small Engine & Mower Repair forum.
