southernkilowatt
- Sep 7, 2011
- 2
- 10
Hi all, first time poster. I may be in the wrong forum, if so please direct me to the right place. I have a Troy Bilt Big Red Horse, 23 HP, 50" cut.
Model # 14AA80TP766
Serial# 1Bo17H30110
Date of MFG 02/07
The long belt, that goes from the motor shaft pulley to the idle pulley located at the rear end broke. I took what remained to Lowes and matched it up to a new belt, according to length and by the book they had in the store. That was the easy part. When I got home, I removed the deck and the seat and battery and battery box. From there I can see where the belt goes, but I see no way to get it around the motor pulley unless I unbolt the motor and raise it up 3 or 4 inches to get the belt past the steering components. Am I wrong? Is there an easier way to do this? I would hate to know that I have to tear this thing all to pieces just to replace a belt?
Please, if there is any advice you can give I would very much appreciate it!
Thanks
Dave (southernkilowatt)
Model # 14AA80TP766
Serial# 1Bo17H30110
Date of MFG 02/07
Thanks
