BB Magnum Thrown transmission Drive Belt
Godzilla2k69
2021 model.
How do I get the belt back on ? The transmission pully is too close to the underside of the deck to pull the belt back over.
Do I need to drop the transmission ?
The wheels are locked and it's in my yard.
lugbolt
it'll go in, you have to wiggle the belt between the pulley and frame. If you can't get it, you'll have to loosen the transmission mounting bolts (don't remove) and let the trans drop a little.
Dumb design, in my opinion.
