Battery for Enduro XT3 GSX 25hp Kohler Command - Part # 725-1707D
greynold99
  • / Battery for Enduro XT3 GSX 25hp Kohler Command - Part # 725-1707D
Does any one know where I could find a compatibility chart for replacing my XT3 Lawn Tractor battery? It's a 12volt battery rated at 300 CCAmps.
I usually get my lawn tractor battery from our local Advance Auto, which carries the DieHard brand now or Auto Zone, which carries DuraLast brand; but I've not been able to find any compatibility chart to match the Cub Cadet Part # to the respective DieHard or DuraLast Part #'s.
Thanks,
greynold99
Scrubcadet10
Moderator
Staff member
if you take your old battery to the store, you can do two things, Check to sure they are the same physical size and be sure the posts + and - are on the same side., and you'll also get some money off your purchase for returning your old battery.
