I have a John Deere 170 lawn tractor with a Kawasaki fc240v-ds00 engine. The battery keeps draing down, when not in use. With key off, i see 6.4 M ohms across battery leads. Started trying to trace and am seeing this load only on red wire ( going from battery + to voltage regulator) to battery-. Is that normal, or is the regulator bad & causing drain?
