Snapper LT140H38ABV. Ran over metal pole 5 inches above ground and hidden in unmowed grass. Shattered the spindle and the ground speed lever control just moves back and forth now and nothing happens - no movement - no noise - no nothing. Know how to repair the spindle etc, but at a loss as to the transmission.
Would apppreciate any insight you have as to transmission correction. BTW, this is a 1994 model and I'm simply amazed at how solid it is. Thanks in advance.
